we use lots of 3 phase inverters at work for energy saving on large fans and such..
due to the "noisy" output of inverters we have to use screened or armoured cables to filter out the EM noise that they create..
some manufacturers aks that both ends of the cable screening is earthed, whereas others ask that both ends of the screening is earthed
if you only earth one end then you can get large voltages at the "open" end, but if you earth both ends you get less effective screening as the EM "caught" by the screening has a circuit to run around then which creates it's own EM field..
which would you use and why?
