Is celotex a better alternative to foam spraying loft?
13 Apr 2011
Antrim
I heard that spraying a loft with foam can cause properties to be unmortageable although I'm not sure how much of that I believe. Is celotex a good alternative and is it expensive?
I am sure it's technically possible to spray-insulate a roof with foam in such a way that doesn't leave the timbers vulnerable to rot, but resulting increase in labour costs would mean that it would be not much more work to use PIR foam boards.
You can save money by using seconds. Only you can say if it's expensive or not.
Spray foam to me sounds like a potential disaster if water or condensation was to get into the other side it could be a nightmare
No just want to get an extra layer of insulation in. It's a two bedroom bungalow. Hopefully easy enough to keep cosy
Plus I like the sound of celotex over spray foam. I am just hoping the roofspace is not a shared one
It is a potential disaster because it stops transpiration of water in the rafters and roof timbers leading to accelerated rot
Do you want to keep the heat in the rooms below the loft or keep the loft space warm?
if you want to keep the rooms warm, insulate above their ceilings, not between the roof joists.
I am insulating above the ceiling also. I want the roof joists done for that extra layer
