I have just changed my very old mixer for a Triton Pirlo thermostatic bar mixer shower (from Screwfix) but the flow/pressure is now barely acceptable. I've tried different shower heads including ones designed for low pressure systems with little improvement. The shower and hot water cylinder are on the 1st floor, the cold water tank in the loft about 1-2 m above, and theshower hose to the shower head is wide bore (12 mm). I see that the Triton has NRVs at the inlet on both the hot and cold side and wondered if removing them is safe to hopefully increase the shower flow/pressure? A shower fitted to a mixer tap on the bathroom also on the 1st floor is working fine with good flow and pressure, which makes me think it is something to do with the Triton.
