Is it the motorised valve thats broken?
25 Sep 2004
Central heating stopped.. fuse blown. I disconnected the pump fuse blew, disconnected the motorised valve no blown fuse but obviously no central heaying as pump wont run.
Does this sound like the Motorised valve or have i just disconnected the signal from another source. If it is how can i test what part is broken can you test the motor?
It is a Drayton mid position actuator MA1.
If it is the MV can i just replace the motorised box, that comes off via a button or do i have to unplumb the whole thing? it is blumbed via 2 compresions and one decidedly nasty looking threaded joint.
If i need a new one what is the best one to buy?
Also can i wire it so that i just have CH and HW until i get a new part?
any help would be appreciatted
Iain
Water's got into the valve head - possibly via a leaking shaft, which means you need a whole new valve.
Head does come apart, have a look, with it off and the power off.
Options - dry it out (hairdryer)
use system with the head off, mve shaft to where you want it.
If no go,
Disconnect brown wire to valve, if it makes the fuse blow.
Put head back on valve, fix in the "man" position (open to CH and HW), then turn the cylinder stat right UP and the boiler stat right DOWN. The boiler will be on trying to heat the HW, but never making it. Meanwhile the valve will let the boiler water through to heat the rads.
thanks for the advice,
unfortuantelly i have no brown wire i presume because it is a mid position rather tah a 2 way
i have
Blue
Earth
Orange
white
grey
Waht one should i disconnect
Iain
I decided to put on a new valve and i still have the problem, everytime the switch is actuatted from the control panel the fuse blows. The boiler doesnt fire and teh pump doesnt come on
Any ideas.. its cold tonight
IAin
You and me both mate, got pretty much the same problem. I've been told it's the motorized valve ( when I had no heating ) but god knows what it is now coz I got no hot water either now.
To find problems like this you need basic electrical knowledge and a test meter and know how to use it.
Very occasionally you might find a visual indication of the fault with careful inspection but the electrical test approach is the normal professional way to find the fault within normal commercial time scales.
Tony
Agile said:
...the electrical test approach is the normal professional way to find the fault within normal commercial time scales.
I can't help but wonder why you post on a DIY site when you keep coming out with sh*t like this. :roll:
