- Joined
- 6 Nov 2008
- Messages
- 837
- Reaction score
- 16
- Country
So tonight the power went off the the heating system. Put a new fuse in the spur and it blew again.
Took off the contol panel and switched spur back on. All ok. Put control panel back and fuse blew!
So off to the shops. Fitted new control display (exact replacement) and fuse blew again
So had a look at pump and motorised valve. Took cover off motorised valve and a spring fell out!. Piece that holds the spring in place has snapped off.
Anyway, i unclipped valve from pipe work (Drayton MA1) and tried turning the spindle on pipework by hand. There was a small amount of movement either way which made pipes clunk quite loudly.
So im none the wiser. The motorised valve wants replacing as the one spring has broken off but is this the likely cause of the problem?
Hope someone can shed some light
