Is it worth replacing old radiators
21 Aug 2019
Hi all I’m getting a new boiler fitted just wondering if it’s worth replacing older bedroom radiators to newer ones, these are approx 20 years old but not sure, they heat up ok but not very hot, not sure if it’s worth spending to change them any advice would be good thank you
yes definately, with your new boiler install you should be getting a flush of some description and your old rads could pin hole, if your pipes are copper I wouldnt worry about them, a flush will sort any problems with them but yep if you can afford new radiators go for it
