For the third time, (it's a long story - and not my fault!!) I had the same leak in my hallway CH pipework, - which is buried in the concrete floor
A few months before this I opened an account with Homeserve ? and they sent someone to repair the problem; and he decided to relace most of the pipework he'd exposed. However he used PTFE pipe and brass compression fittings to effect the repair and there was a routing issue. One pipe had to go over the other and, as it was short distance and he didn't want to use several bends, to resolve this he used a reducer to go from 22mm to 15mm and then a second one to go back from 15mm to 22mm.
The CH seems to be working ok but my question is, as this narrowing has been put in the main supply pipe is this going to cause any problems in future. The floor has been lifted three times now and I'm loathe to have this concreted over again and the floor made good, just to have it lifted again at a later date.
Oh and before anyone says, I've thought of having a trap door fitted ready for next time!!!
