Is this the right fitting? (just drilled through pipe)
17 Aug 2004
I have a new house and the heating pipes are 10mm pvc (or what ever type of plastric they are) and i just drill through one. Heating ids off so i have contained it but what the best way to repair these? will this do the job -
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100985&ts=85503&id=21527
As it says for copper pipe only but the the 15mm one says for copper and plastic?
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100985&ts=85032&id=28263
Hope someone can help tonight as i need to get this done ASAP in the morning
Many thanks
Thanks for the reply, i noticed i posted the 15mm, but i have editied my post above will the 10mm one be ok for this sort of flexible plastiv pipe i have on the heating?
Yes.
You can get them from Q+B, you will need two inserts aswell.
Make sure the cut of the pipe is a clean one with no jagged edges ;)
Thanks so much, what inserts would i need from Q & B? as the wiffe will have to get this in the morning?
Softus - The last link, is that the best to get then, as i will be covering this up so i would want the best. Just confused as a non plumber type person that the copper fixing is the best to use on plastic piping?
Many thnaks
Thanks, will i need inserts for the one from screw fix?
May get that one tomorrow (temp fix0 and then order the copper one!
Wel not to leave any stones un-turned, the fitting worked great!
Many thanks for the backup!
Cheers
The Pegler fittings are particularly good quality, but the reason I suggested a compression coupling is because I don't know how the condition of your existing plastic pipe - if it has any scratches on then you risk having a leak past the O ring of a push-fit fitting.
Er, they're brass, not copper. ;)
