Hello all
I have an issue with One Radiator that I hope you can offer some advise on.
I had a Type 11, 1000mm x 600mm Radiator Installed in the Living Room which had no Radiator prior, in 2018.
Even though the Radiator got Hot it never sufficiently Heated the Room.
In 2022, I had the Radiator replaced with a Type 21, however, this too is not Heating the Room sufficiently even though it should be more than capable of doing so.
All of the other Rooms get to their Set Temperatures in approximately 1 Hour, however, the Living Room struggles to get up to Temperature in 4 Hours, sometimes longer.
The Radiator was connected to the existing 15mm Copper Pipework utilising 8mm Plastic Pipes.
Could the use of the 8mm Piping into the 15mm Copper be the issue?
I have had the System Balancing checked, multiple Times and it is correct.
Thanks in advance
Kevin
Thanks in advance
Kevin
