iwb5123 indesit
17 Jun 2012
Avon
My washing machine PCB as blown, one of the relays has burnt out because the drain pump got jammed.
On top of the relay in stats
HF3FD
012-ZTF(88)
No 10 A 250vac 85.c
5A 250VAC 85C
Could i switch burnt relay with another relay from an indesit machine which stats the following
HF3FD
012-Z3F(088)
10 A 250VAC 85C
6A 250VAC 105.C
That relay comes in 2 types, one with 4 connections and one with 5. As long as the replacement one has the same number of connections you will be OK.
Edit:
Just checked the specs and the only difference between them is the contact material so it will definitely be OK. :)
