Litherbeth said:Thanks Guys! I have actually tried turning the rads down upstairs and it made no difference. The house is older than 3 years but the previous people had a big extension done and renewed the system. I am not sure if is a drop system or not. What about the speed of the pump? Should I turn it up to III? It gets pretty noisy then. Wouldn't sludge show itself a bit when I bled the rads? Powerflushes are more expensive than new pumps aren't they? How would you diagnose which it is?
When I had the boiler looked at - he put some sort of meter thingy on it and it read perfect, he said. It certainly seems to be on all the time, struggling to heat the rads which are (I forgot to say) erratic. They go warm and cold throughout the time they are on. So heat is getting through, although it takes up to 2 hours sometimes for it to warm up.
Thanks a lot - look forward to more replies - Thank you
The heating system is reported as being 3 years old. How old is the house PP?Prof.plumb said:Sludge in a house that age?! Behave yourself chris! I ll put a wager on my diagnosis. Yes there are other possibilities but im stating the obvious and most likely.
