Kettling
15 Mar 2005
Hi
Can anyone tell me the best way to stop kettling in my heating system.
Without a bit more information the most likely answer is no. How about:
1) Do you know what kind of system you've got: open vented or combi, fully pumped or gravity?
2) Does it happen all the time or just before the boiler switches off?
I have got a Myson Apollo 50 Si, when the heating is on it sounds like water is whoosing in the pipes. I have got an Indirect boiler system with the expansion tank in the attic. I have bled all the radiators and no air came out. Could it be the pump is not working as it should be because i have never had it changed yet
And did it start suddenly? Does it do it with the boiler temp set low?
They all ketle eventually it seems. Could try boiler descaler, boiler silencer or a System descaler/restorer. All are liquids you introduce.
