Hi there,
Did you ever get to the bottom of this Postik?
I have a Tribune XE which exhibits the exact same behaviour as yours down to the pressure at the tap when the tundish is about to start dripping.
Interestingly I've had the cylinder replaced twice under warranty (1st was sticky diaphragm which made the tank excessively noisy on heating cycles and the 2nd only last year due to a faulty installed Immersion heater). They have all suffered the excessive recharging required so I think it's definitely something external to the cylinder.
I have to represussure mine every 4 months almost to the calender day. I too have 2 bar showers and multiple mixer taps in the house. I do wonder if there is some back pressure from the cold feed as mine was never installed with a balanced cold feed (it's just blanked off). Lazy new build installers I guess here. So do wonder if due to all the mixer taps this is the culprit.
After I represussure it works fine for a other 4 months. Wondering if you solved yours or just lived with it.
Cheers,
Cheers,
