Hi Guys, hope someone can offer a bit of advice on final circuits and kingspan. Am currently renovating a 200 year old cottage. Intend to use 100mm kingspan within wooden frame as insulation, finished with plasterboard and skimmed. Property consists of both stone walls and a 50 year old extension of single brick. As there will be a membrane between the outer walls and kingspan my only option will be to run the cables in a service void between the kinspan and plasterboard. Whichever method I use is at some time going to need to be routed through the kingspan either through the ceiling, which will also be insulated with kinspan. Appreciate that circuits will need rcd protection as wiring will be less than 50mm from the surface and that either boards or trays would be a safe bet where wiring runs through the attic space, your comments would be appreciated. cheers Barney346
