Hi, I'm new here.
I'm planning a kitchen installation, going to install electric oven, gas hob, cooker hood, fridge, separate freezer, possibly under cabinet lights. My plan is as follows, I'd welcome any comments and criticisms please!
Electric oven & gas hob
2500W oven, so planning a 16A radial from CU to cooker outlet in 2.5mm t&e.
Both hob (for igniter) and oven will be hard wired into the cooker outlet plate.
There will be a fcu above worktop level adjacent to hob containing 13amp fuse
Wiring will probably be surface run under cupboards, but chased into wall behind tiles for the fcu
Due to the short length of concealed wiring, as I understand current regs the cable needs to be RCD protected, so planning a 16A type B RCBO supplying only that radial
Fridge & Freezer
Dedicated radial supplying both appliances in 2.5mm t&e from 16A RCBO via 13A fcu above worktop level
Unsure from research whether f/f on rcd is a good idea, but due to concealed wiring to fcu I don't have much choice unless I start burying steel pipe in the walls.
Cooker hood
Spur from ring main, to fcu located in kitchen cabinet adjacent to hood, hood hardwired to this
Under cabinet lights
Haven't really thought about this yet, I think only option is to take a new run from existing lighting circuit? It'd be much easier to use the ring main but not sure this would be allowed?
Thanks!
Richard
Fridge & Freezer
Cooker hood
Thanks!
Richard
