Kitchen sink drain knackered
No just undo it from the trap. Turn the nut clockwise as you look at it from the cupboard, the pipe then pulls out. Then you put the washer and nut on new piece when you feed it in through the wall
so that pipe would need sawing off and replacing on the inside?
It won't need sawing off, just loosen the connector on the trap and it'll pull out. You should have one continuous piece coming out of the trap, through the wall then the elbow and down the wall to the drain. The 40mm black pipe I showed above goes into the right angled part on this image of a standard trap.
Easy DIY job. No need for a plumber.
Not for the OP it isn't, they don't have any knowledge of waste plumbing which is clear from their posts. I agree a handyman or any competent DIYer can do it but this is out of the skill set of the OP.
A plumber is likely to have everything they need on the van avoiding any hassle with "just have to pop down to Wickes/the merchants" which you'd get from any mates/competent DIYer etc.
All the OP has to do is do some research, on YouTube. Plenty of info. No need to call anyone. It's a simple job. He can always call on people here for solid advice if he hits a wall...
