Fully pumped but not sealed ch system.
Did have problem that scorching water from the bioler was only lukewarm when it reached the cylindar. Fixed that mainly by letting air out (air lock key in the pipe that continues past the input to cylindar).
Now the water is scorching hot when it gets to the cylindar. But not when it comes out (at the top, and from the taps).
Temporary saving grace is that the emersion does give scorching hot water from the cylindar, so something's ok.
Any ideas on how I can 'diagnose' the cylindar problem further would be much appreciated. I assume it has a coil inside, but could be a primatic with air etc inside .... I don't know how to tell from the outside !!
Thanks in advance for any suggestions .... Mike
