Ladder Towel Warmer
20 Apr 2007
Cornwall
I tried posting this in plumbing but the forum is so busy I did not get any serious replies before it was pushed way down the list, so hoping someone here can help.
I have to install a ladder type towel warmer in a bungalow with solid floors. The system is fully pumped. Is it possible to feed the towel warmer from the top (i.e. upside down) to avoid having pipes down the wall from the loft?
TIA
Do you mean connect teh pipes to the top of the radiator?
no- the hot water will heat the top of the radiator and the rest will stay cold - you have to feed the water in/out at the bottom of the radiator.
How you get the pipes to the radiator . . any way you can, Duct in the floor, from the other side of the wall . . .etc.
