Laminate flooring the edgy bits... part deux
18 May 2008
Bedfordshire
Quick one..
When laying the underlay to the edge of the skirting can it be firm to the edge or does it have to have a 10mm gap for inclusion in expansion? I know the underlay wont expand or contract like the laminate will but just wanted to check if i could fit underlay firm to the edge without worrying about it.
Also would it be wise to lay all underlay and cover the whole floor(thinking of doing whole of downstairs approx 35sqm 5 different rooms or lay underlay as i go?
Last one and this ain't looking so quick now but I am not sure how I am going to put the flat beading down around the toilet? do you put it down around the toilet?
Lay the underlayment as you go otherwise you will rip it when walking over it too much.
Lay it as far as you can to the walls, no need to keep expansion gap for underlayment.
Flat beading around a toilet pan will be difficult. If possible remove toilet pan before installing floor and place the pan back afterwards, sealing the pan to floor with silicon. If not possible to remove toilet pan, leave expansion gpa around pan and use silicon (=flexible)
