Large floating desk - seems plausible?
24 Feb 2026
Hi all, first post here.
I'm currently refurbing my home office, and got my heart set on a large floating desk, done a lot of planning, but would be good to get a bit of review from people who almost certainly have more experience than me!
So, the desk is going to be 2610mm x 700mm - a large span, covering the full length from the window on the left to the wall on the right.
All 3 walls are brick
I'm planning on fixing 70mm x 70mm battens across the full length of the 3 sides, fixed with beefy concrete screws, straight into the masonry.
Then, in addition, i was planning on use 2 or 3 of these 600m span L-brackets across the width.
The desktop itself would be 40mm thick full stave iroko kitchen worktop from here:
Anyone with more experience built something like this, or have an opinion on whether it should be strong enough to not sag?
My preferred option is that its fully floating, but i guess my fall back is add a couple of legs to support if needs be.
Going to wall mount the 3 monitors to save on load too - other than that, there won't be anything of weight on the desktop - just my elbows and the actual weight of the desktop i guess.
Used a sag calculator, https://woodbin.com/calcs/sagulator/, and seems to be acceptable, without the L brackets.
Feels like i've planned all i can to give it the best shot of being sturdy, but it's my first time doing something like this, so being extra cautious.
Anything i've missed, or planned wrong fixings etc?
Thanks in advance for any feedback
Floating wise, yeah, no issue given that you have supports at either end. Sagging- yup, it will sag over time.
I used to work for a cabinet maker- long spans he would use steel box sections or L profiles to support the front edge (set back slightly).
Thanks for the feedback.
Yeah, maybe L profile the full length set back 100mm or so would be a good addition, recessed into the side battens. Will give it a go. Rather go over the top than not enough. Thanks
Battens along the 3 sides. My desk top is oak kitchen worktop so the extra support was essential
Thanks for the feedback. Honestly, putting some drawers under to support wouldn't be a bad thing. it's still big enough that it will look good, and would give me more storage!
