I've just got my second decorating job - 4 bed rental property. I'm doing it cheap, as I'm not a timeserved dec, or decades experience. My main worry is the cracks - it is a sixties house, 64 I beleive - the type with horizontal wooden tongue and groove cladding.
1 the construction is probably breeze block and brick skin, is it likely to be just ordinary plaster on the walls?
2 Most of the cracks are vertical and from skirting to ceiling. I don't mind the ones in the corners, as I have had some success in the past by knocking away at the loose plaster to give say a 1/2" to 3/4" gap in the corner and filling with expanding foam, then caulk over the top. I was quite happy with that approach in room corners - surely the expanding foam with caulk over will not crack?. Anyway what I want is some tips for dealing with full room height cracks in possibly original 1960's plaster. These cracks are upto about 4mm wide, mostly about 1 or 2 mm ( all showing as ugly black jagged lines going up the emulsion walls). Obviously there is some movement in the foundations over decades to cause them in the first place.
I'm looking for detailed procedures if you have time and product recs.
Can u chisel out full room height cracks to make them say 1/2" wide and just skim with something. I have had a go at plaster skimming in my own bathroom and could do a bit at this job, although when dealing with cracks, not really sure if cracks would just appear through the say 2mm plaster skim later. I don't really want to knock the whole lot off and replaster as I'm on a quote and trying to make a quick buck. I told the owner I couldn't guarantee anything with the cracks, as I didn't really have the experience - her reply was something like 'I wouldn't worry about it too much, as long as it looks better than it does' even so I'd like to do the best job I can. Sorry for lengthly post and lack of photo's, may photograph tomorrow to aid suggestions, or is problem clear enough.
thanks
thanks
