Some time ago I posted here about a problem with an NEC monitor displaying horizontal lines across the screen. After establishing that it was the monitor rather than other components I decided to have a peek inside and check for loose connections. There did see to be a small impovement and I learned to live with the screen display.
But things have got steadily worse resulting in me seeking the advice of a qualified technician. Seems the problem is down to the main board processor overheating - lines magically disappear when coolant sprayed on the board. So a replacement board should solve the problem!
Now my quandry is that a replacement direct from NEC is around £150 which represents about 1/3 the cost of a new monitor. Not sure if it is a good idea to replace the board or look around for a similar spec. new monitor.
EDIT: While the cooling of the processor cured the problem I still do not know for sure if the processor is the problem and damaged or if the heat is caused by excessive voltage.
An alternative may be to try and find someone who breaks computer bits for spares - but my searches so far reveal nothing.
Anyone have any suggestion - apart from get on with it you tight fisted git
