Lead risk with steaming wallpaper?
Keep it wet and all will be well. Better getting it skimmed rather than lining paper unless you are doing it yourself.
How old is the house?
If the old paint under the paper is emulsion or similar, it will not contain lead.
Lead paints were used on woodwork.
The house is 1950s - great news that lead is only on wood, husband should fine that reassuring. It is yellow on top of some blue/green and not flaking (well, unless you hit it with a scraper which I don't think quite counts). Is there a way to tell if it's emulsion (I am even more clueless than most.)
On walls and ceilings, emulsion, if loose, can be taken off with a broad metal scraper and water (so can distemper, which softens in hot water, not cold, and may have been used at that age). Emulsion is quite hard but thin and flaky. If it doesn't come off easily, leave it on.
Distemper has a distinctive unpleasant smell when you attack it with hot water, as it is made of boiled-up horses hooves.
On woodwork, gloss paint, undercoat and primer, which might contain lead, is oil based and needs a hot gun or blowlamp (not recommended for lead paint because of the fumes) or chemical stripper to get it off.
