leak at manifold
24 Jul 2006
Manchester
fitted living room radiator last night and then discovered a leak at the manifold under the floor boards, the pipes have all been soldred
but i possibly nicked the 10mm pipe whilst wrestling with pipe to fit too new radiator !!!!
will this have to be re-soldered ???
also was thinking one of these may be used, has any one ever used these
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100985&ts=69139&id=12589
thanks
it is on the right hand side bottom pipe going into manifold, the one you just cant see
You can buy a new brass manifold. Cut the pipes flush with the old manifold and clean up the pipe. Then resolder.
Looks like the pipe going between them is a bypass?
