(Main Combi 30 Eco)
Hi All,
I wonder if you can help.
I changed a clogged plate heat exchanger on my boiler a couple of months ago. All seemed to go well and hot water was consistent again.
Since then however, I have had a leak from the bottom of the boiler. Didn't notice it for couple weeks until one day came home to see it leaked from worktop to floor. Initially was small but has now grown more significant (and emptying the small bowl from under boiler a few times a day)
Are there certain steps to follow as process of elimination to identify the source of the leak?
If it's relevant, I was only able to change one of the plastic washers in the pipes that connect to the PHE as couldn't get the other out. I also didn't grease/silicone these connections as wasn't clear I had to.
Also if relevant, the water appears to be coming from directly above the hot water out pipe below the boiler.
Thanks in advance for your help guys.
Hi All,
