Ok. so I was having a nosey today to see if I could shut off the water supply to a bathroom tap as it needs a washer. While having a look in around the water tank, I found a new problem. I noticed a dripping on the floor from the tank. On further inspection I noticed the floorboard had been a bit wet at a previous time. Now, however I could see a drip.
I got the phone out and took a few pictures. It was drpiing from a valve of some sort at the rear of the tank. I put a towel down and was able to turn the square looking nut to shut the water off. It really did take a good turn maybe half a turn or more to stop the drip.
While I'm happy the dripping stopped and I didn't flood the house, I'm a bit worried as I'm not sure what this leaky valve is or why it would just start leaking like a drip every 6 seconds. I'm in the house 10 years or more, so why would it start now And why was the square nut so loose...?
also... I have had a gurgling/bubbling sound from the hot water tank when the oil fired burner is heating the water.
sorry it's taken so long to explain and thanks for reading, any enlightenment appreciated.
