This is my first post-and I hope I do not offend by my lack of knowledge with plumbing matters! Anyway on with the issue I am having & details etc.:
The problem I am having is that I have a leak from en-suite electirc shower unit(1st problem with this 5 yr. old unit) and this has created a 2.5'x 2.5' wide stain on the downstairs ceiling. This is definitely coming from shower as the leak only happened while shower was on and is directly overhead.
*I have checked shower tray - appears fine.
*Checked around the trap and there is no build-up of residue etc.
*The seals are intact also.
Is there anything else I need to check before I call in the plumber!
Could there be a block/loose connection on the pipe run, joining main downpipe down into gully system?
Am stuck for ideas and any recommendations/ways of checking this would be welcome.
Regards.
Cathal.
Regards.
Cathal.
