Hi.
I have recently had to replace the PCB on my boiler and found out that there was water dropping on it from the joint between the actuator and the diverter valve.
The new board has been pulled out of the way. The drip is hardly anything, but enough to damage the board.
I have removed the actuator and noticed a small amount of water inside, where it connects. The water is dripping from the retaining clip.
Do I need to replace anything?
Someone told me to put a bit of silicone grease in there.
What should I do?
Thanks.
What should I do?
Thanks.
