Good evening,
I have a little leak from the underside of a radiator drain valve. I think the water is coming from the drain bit. Is it possible that a screw is loose or is it more likely to be a worn out washer?
Also would i need to drain the system to repair either fault?
Many Thanks
Many Thanks
