    Dismiss Notice
leaking radiator tail
Discussion in 'Plumbing and Central Heating' started by chazzbo, 12 Sep 2014.
  1. chazzbo
    chazzbo
    12 Sep 2014
    2
    Thanks Received:
    West Midlands
    Country:
    I have a new towel rail radiator but keep getting leaks when I install it. It comes with a threaded tail. I wrapped the tail in plenty of PTFE but have found I can't tighten it just keeps going up into the radiator. needless to say this leaks.
    I then bought this tail
    http://www.screwfix.com/p/radiator-compression-valve-tail-15mm-pack-of-2/10954
    I also wrapped this in PTFE and was able to tighten it. However this also leaked slowly. Not sure what I'm doing wrong.
    Anyone have any advice? Any other sealants worth using?
  2. leakydave
    leakydave
    2 Nov 2005
    959
    Thanks Received:
    102
    Gloucestershire
    Country:
    Loctite 55 onto a roughened thread with a bit of Jet Blue... and cross your fingers.
  3. Sponsored Links
  4. have a close look at the towel rail, i had one once i couldnt stop leaking no matter what i did, after a few attempts on closer inspection there was a hair line crack in the radiator (customer supplied cheap internet crap!)
  5. chazzbo
    chazzbo
    12 Sep 2014
    2
    Thanks Received:
    West Midlands
    Country:
    Will double check the rad - I'm the king of cheap internet crap!
    Thanks for the sealant tip, worth a try. Roughened thread? is that with a wire brush?
    really appreciate the advice.
  6. Sponsored Links
  7. leakydave
    leakydave
    2 Nov 2005
    959
    Thanks Received:
    102
    Gloucestershire
    Country:
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
