Hi
Just moved into a new flat and i found that one of the radiators has been leaking (and it looks like for while too). I will try and expla
On closer inspection i can see that water is coming out from the join underneath the nut on the thermostat and also some water is forming on the surface of the other valve (when the cap is removed). see pics.
I know nothing about sorting out radiators, so any help in what steps i should go about to fix this would be great. As far as i know this is the only leaky radiator. I've tried stop leaky pipe compound, but it did not work as the pipe was still leaking as i tried to fix it and the putty never dried.
thanks
thanks
