leaking rads with back boiler
13 May 2008
Leicestershire
can anybody help my mother got a old back boiler and leaking rad upstairs i know she will qualify for a grant for new central heating i removed the rad because badly rusted around valve and capped the two pipes now radiator down stairs leaking same place. ??
thanks but can u tell me is there a pressure guage on the back boiler as with a combi ? maybe because i removed rad pressure was built up to cause leak in downstairs rad?
No, it's just bad luck.
If one rad rusts throught then it is quite common for others to follow as the same contaminated water and corrosion is in the entire system.
