Leaking Sink
20 Nov 2009
Alright guys,
my sink is leaking, specifically this bit around where its actually joined onto the bottom of the sink
I'm guessing there's meant to be a seal around the bottom of the sink and that part that has dissolved.
Do I need to get a new one of those bits or can I just use some sealant to go round it? If I need a new one I assume B&Q etc do them? It says A McAlpine out of interest (as in Alfred?)
Thanks for any help
That`s Sir Mac Alpine to you :idea: and yes, try some sealer if you have a tube handy - cost of new tube won`t be far off cost of part :wink:
McAlpine a fine Glasgow company, first class Plumbing fittings of Clyde Built quality.
Esoo, any good Plumbers Merchants will stock McAlpine fittings.
Thanks guys,
just out of interest does this thing have a name? Is it a waste trap?
Alright guys,
Thanks for any help
Have you tried tightening the large nut where the plug goes?
A large flat blade or box spanner will do it.
There is a black rubber seal underneath between the sink and the white plastic.It will not dissolve.
Thanet.
the waste might be mcalpine but the pipework is rubbish and no sign of a trap :?: :?
As in its leaking because that's untightened itself and thus there's a tiny gap between the sink/seal? I'll give it a try.
As for rubbish pipework; what's missing? That's the second little "sink" by the way, the main one is to the left - that might have a trap?
Well, that didn't work and it has caused the other side to start leaking now :/ I think the washer is buggered with that one since its one of the pipes thats leaking
Looks like a B & Q waste kit to me which are *****. :lol: Will it not tighten from the top :?:
Might pay you to buy a new basket strainer for £4 than mess with it for hours. :D
yeah I just realised that he said tighten from the top heh. I've had a crack at at with a pair of pliers and it seems to have done the trick, although it kept turning as if it wasn't tightening. And yeah I think its from B&Q.
What exactly do I need to buy if it doesnt stop? The whole thing or just something like this;
http://www.plumbworld.co.uk/sink-basket-strainer-waste-314-20367/10001
ta,
coming up tomorrow; new topic - leaking pipe under sink!
That will do you or the B &Q ones will be ok.
Not happy with their waste kit but see if you can do the job without needing a new waste. :D
Rip it all out mate, go to a Plumbers Merchants & get all McAlpine fittings to do the job, it'll save your blood pressure going through the roof!!
I would tend to agree with Delta and redo the lot as you could be there all day! :(
