Leaking Triton electric shower
23 Mar 2010
Hi. Triton t70gsi+ installed a couple of months ago.
About a week ago I used the shower to fill a bucket and set it to the 'pulse' setting. I noticed water dripping from the pressure release valve. Assumed that it didn't like the pulse setting? Ordered a new PRV. A couple of days later noticed a drop of water at the very base of the unit, in the centre of the cover, water was cold. Water wasn't dripping from the PRV after adjusting the shower head setting back to a less intense output (don't know the terminology, sorry). Assumed that the droplet of water was coming from the PRV but sitting inside the casing and finding its way out at the lowest point. PRV arrived, PRV replaced. Still the slight weep from under the casing. This only happens when the shower is on. Curiously, it doesn't seem to leak in the mornings but does when I have a shower in the evening. It's not a lot of water, less than a teaspoon full. Any ideas what I should be looking at please? Edit to add that it only leaks when the shower is on. Thanks for reading.
Could be stabilising valve, but only months old is be getting the installer back or Triton out to it
Thanks both. Yes I'm going to go back to the installer on this.
Agree with Fred Blogs about the guarantee.
