- Joined
- 24 Jun 2020
- Messages
- 8
- Reaction score
- 0
- Country
I hope you can help me.
I am in the process in building a lean to pergola and wanted to check if my plans are good enough.
I am using 150mm x 47mm (6x2) Roof Joists with centres at 739mm
This will be held in place by a 150mmx47mm (6x2) attached to the brick wall of the house.
At the front - 2 x 100mmx100mm (4x4) posts and 150mmx47mm (6x2) accross.
Width: 3740mm with approx Length of 3000mm
The roof will be covered with 10mm Polycarbonate Sheets cut at 717mm by 3000mm
Roof sheets calculations: joist centres 739mm - glazing bars centres take up 8mm on each side - so I need to deduct 16mm. Which leaves me with 723mm. I also need to account 3mm on each side for breathing space. So this leaves me with 717mm..
The two posts will have a approx span of 3000mm
The rood will have a 5 degree drop.
The posts are 3000mm in height of which 721 will go into the ground and cemented.
For extra support I was thinking attaching few coach bolts to the decking structure. But I am not sure if this would be a good idea.
Would you change anything and does the structure sound safe?
