i wish to use a security lighting controler to turn my porch lights on and off.
at the moment i have one of these wired in
http://www.maplin.co.uk/Module.aspx?ModuleNo=37966
but i am tempted to swap to a motion based one like this
http://www.maplin.co.uk/Module.aspx?ModuleNo=45045
problem is the combined wattage of the 2 lamps in my porch is only 2.4w, hence why i don't mind them being on a while using the original switch.
but this is well below the recommended minimum and why when turned off the led lamps are still on but dim, when i exchanged one for a halgoen lamp they were both off (when the switch was off).
so is there any such light switch that can cope with such a low wattage?
is there anything i can use to trick the switch into thinking the wattage is higher than it really is?
any help would be great.
ian
ian
