I am retiling my bathroom with large 25mm x 40mm tiles laid horizontally (bricklike). From the sticky in the tiling forum I understand that for large tiles the surface needs to be as flat as possible.
However one of my walls is slightly concave. The majority of the wall is only out by ~2-3mm both horizontally and vertically however towards the centre of the wall this sharply increases to 6mm horizontally and 4mm vertically out of line.
Is the unevenness of this wall likely to pose a problem when laying my tiles?
If yes, There is not enough space to dot & dab plasterboard as the bathtub sits in an alcove created by this wall and two others which is pretty much the size of the bathtub.
So presumably I would need to float the wall flat with plaster, timber grounds and a featheredge but I am unsure which type of plaster to use for this job either:
Single coat of Bonding Coat or
Several coats of Multi-Finish
or what size grounds to use having skimmed but never floated a wall before?
As the majority of the wall is only 2mm out of line would Bonding Coat be appropriate I have read that applying Bonding Coat thinner than ~5mm can create an unstable background for the finish coat.
Many Thanks.
Many Thanks.
