We moved into a condo not too long ago and we finally bought a ceiling track light to install....
There is a spot in living room with a fixture pre-cut out with wires.. There was nothing installed there before, just a white cover..
It's a newer condo (built in 2008)...
I have installed a bathroom fixture in my old house but i have never seen this type of wire setup before..
There are 4 coloured wires:
3 separate red ones all capped with the same cap
3 separate white wires all capped with the same cap
the green and copper wire (ground i am assuming)
and a single Yellow wire capped
what's the red and white?
what is the single yellow one for?
is it for a ceiling fan?
i opened up the light switch to where i am assuming it goes to cause the one switch doesn't do anything right now..
the one on the left turns on a power plug (our lamp), which has 3 red wires connected to it.. (1 on top, 2 on the bottom)
the other switch, which does nothing has a yellow and red connected to it....
The white wire is no where to be found so i don't know what the White is for? which one is the hot wire? there is no black wire? never seen this setup before ; <
any help would be GREAT
