Lime mortar for repointing
24 Jan 2011
Suffolk
Hi -
I am about to engage a builder to repoint the front of my house which is a 1925 semi , built in soft red bricls and lime mortar.
Next-door have already had theirs repointed and it doesn't look good really so I want to avoid the same pitfalls. Basically their lime seems overly bright white and to make things worse the new pointing seems to have been brushed over in such a way that the joints now look extra wide.
My question is - does anyone kow a way of avoiding the bright yellowy white colour of new lime re-pointing? Ive heard about 'soot wash' on here but I think that might darken down the bricks too much at the same time.
Any advice much appreciated.
Thanks a lot.
Richard
I've been researching lime mortar myself recently as I need to repoint the fireplace I've just uncovered.
These guys's seem quite helpful:
http://www.lime-mortars.co.uk/lime-mortar
They do a range of mixes and colours and will also match what you've got currently if necessary.
Hi -
Thanks a lot.
Richard
That's the normal method of finish for lime mortar. Re pointing often makes the joints look bigger, as the edges end to break off slightly over time, and also when the joints are cut out. Having a slightly recessed joint can help, but it's not as weatherproof.
Tuckpointing makes a smaller joint, but it's big money to do unless you DIY.
