lintel size
23 Dec 2007
Yorkshire
hi, i want to make a 6ft opening in a single leaf internal wall. the wall is holding up four 9"x3" bedroom joists which are in turn holding up a 3" thick cinder block wall which is 8ft high.this cinder block wall is not load bearing. what type and size of lintel would be suitable ?
Sadly, this work requires building control approval, who will require calculations from a structural engineer.
thanks for replies.
shytalkz,which is the best (strongest) from the two you mention?
dextrous, will be applying to building control,just trying to price up at the moment.
