A bit off topic, but a cautionary tale.
My ex Ma-in-law wanted a curtain rail putting up in the kitchen. A typical 70's Woodrow council house (even called the estate Woodrow!). Now, for info, prior to her moving into this house it had been subjected to a house fire.
So. I gets me drill out, drill a hole in the plasterboard through to brick (?? laughable) for the end bracket etc. etc.. Second hole a foot into the window space. I hit the metal lintel. Damn thinks I, I get down and change the drill bit to HSS, light a tab and jump back up on chair. I lean on the drill like a maniac. PSsssHHHT!! It wasn't a steel lintel at all. It was a ferkin copper gas pipe above the window frame!! I tell ya, you've never seen anyone shift so quick to turn the gas off! (and I'll admit I was highly "shaken" afterwards).
At the end of the day, despite "deliberate damage" and an emergency call out, the LBC came out and said would be no recrimination towards the tenant as the gas pipe should not have been hidden up there (+ MIL was a pensioner!). If the contractors thought/knew the original gas pipe under the floor was damaged then they should have dug the floor up and replaced it there. That was part of their contract remit apparently.
Moral:- Never, ever, assume anything!!
