I've just had my central heating boiler relocated and a new unvented cylinder professionally installed. I was surprised at the hot water temperature coming out of the taps was so hot even thought the cylinder stat is set at 50C so I started looking at the pipework. When the programmer was NOT telling the boiler to heat the water the cylinder's coil pipes still seemed very hot. I let everything cool down overnight and have run the system up and concluded that the Salus Automatic Bypass Valve is definitely letting heat through to the cylinder even when the system should only be heating the radiators. All of the radiator TRVs are fully open (since the house is still quite cold and <14c) so I assume the plumber has not set up the automatic bypass valve correctly? I've seen other threads on how to set it, but he'll be coming back for a small leak anyway. HOWEVER, my worry is that given tonights Googling to try and understand this I've just seen a post that says the ABPV should NOT bypass the DHW valve on the cylinder coil circuit if the cylinder is unvented. My boiler has an external pump so I assume there is no "overrun" control and the system is an S-plan with two 2-port valves. Any advice on if I need to complain that he's piped it up incorrectly?
Thanks.
Thanks.
