Location of corner post between bi-fold doors
6 Aug 2014
Suffolk
Hi, I am shortly to embark on building a single storey extension, which will include bi-fold doors on two sides, meeting in the corner. (Steels above). The walls aren't all doors - they're roughly half brick, and half door.
The roof will be supported at this corner point by a steel post, the calc's for which have been approved.
However, the post (100 x 100) is in line with the inner leaf of blocks.
I would like it in line with the outer leaf, so the doors will effectively be flush with the outside, with a recess on the inside, rather than vice-versa.
Assuming the door frames are approx. 75mm wide, this arrangement should work.
However, do the doors need bringing further back? - I heard they need to cover the cavity by a small distance. If this is the case, then the post will need packing out, effectively increasing its size.
The engineer has come up with some suggestions to allow the post to move to the external corner, but I don't want to over-cook it & end up having to increase its size to accommodate the door frame. He has also asked if I'm happy with a 150x150 post as this apparently makes connections with the PFCs easier, but I want to minimise the size of the corner post.
In summary, considering the above, where is the best location for the corner post?
