- Joined
- 27 Jul 2021
- Messages
- 2
- Reaction score
- 0
- Country
Hi All
I Have a 1930’s property semi-detached, and we have just had a new roof installed, we had the old tile with torching on the back that was crumbling everywhere.
Currently the ceiling joists span 7.7m and are 70mm x 50mm with a couple of cross braces that span the 5.5m and are 100mm x 50mm.
We will be throwing away all the existing insulation as its covered in the torching and cleaning the space. (Not sure the thickness currently less that 150mm and has been compressed to 70mm in most of the loft.)
What's the best way of tackling this i read you need 270mm of insulation now.
I was going to cross brace the old joist with some c16 120mm x 45mm to add 100mm more insulation but I cant find any 70mm thick roll to go between existing joists.
then just OSB3 T&G over new joist
Any Help much appreciated.
