I was going to insulate my loft under the Government’s CERTS-backed scheme using Mark Group (Yea haa?) - but was hesitant as they refused to deal with boarding and electricals properly: That scheme has now expired.
According to Mark Group's survey I have 70 sq meters of loft with 25mm of existing insulation (I reckon it is more like 10mm insulation at best).
I seem to have normal (400mm wide) joists, that are about 10cm deep.
The recommendation generally is to U Value of 0.16 = 6.25 Thermal resistance [R] (m2K)/W.
I reckon I can best this by:
1. Using 100mm Loft Roll Insulation from Wikes in between the existing joists (2.25 Thermal Resistance)
2. Cross / counter batten with 170mm timbers, allowing
3. 170mm Loft Roll Insulation to be installed in the new raised gaps at 90 degrees to the 100mm, then
4. baardin over that marking with position of electricals for future easy location
I assume I should use Terracotta pots around down lights that do not have a fire-rated housing, and leave 2"-3" of clear space (no insulation or boarding) around the lights?
By my reckoning 70 sq meters of insulation = £400 at today’s prices.
M'
M'
