I have literally read hundreds of posts on the need to fit a vapour on the warm side of loft insulation at floor level. I.e. plaster board, vapour barrier (not needed if foil backed plasterboard), joists and loft insulation.
Background - Coming to the end of refurbishing our 1940's 3-bed semi and unfortunately I found out to late it is a good idea to either have foil backed plasterboard to ceilings or a CONTINUOUS vapour membrane.
The loft is 8mx6m with lots of headroom, dry with no signs of previous condensation. The roof has no felt above or below the rafters, only tiles. So there is good ventilation at the eaves and roof.
Currently no insulation as the old stuff was unrecognisable and binned. The plan is to lay 100mm roll insulation between the existing 4x2 joists, cross batten, lay another 100mm of insulation and board over the top. Bingo.
Now back to the vapour barrier, before any insulation goes down. Remember I am not pulling any ceilings down so it has to be a retrofit if anything. Some say the membrane needs to be cut into strips, laid between the joists and stapled every 6 to 8". Others say it can be simply draped over the joists?
I can see the strips working to some extent, even though they are far from a continuous barrier perhaps better than nothing? As for draping the membrane over the joists and infilling with insulation, not sure about this. Will this not trap condensation against the joists causing problems?
I welcome your thoughts and suggestions.
Oh if it helps I intend to use a non-itch loft roll insulation made from 85% recycled plastic bottles
. Not sure if I'm allowed to mention the exact product so I will not for now.
