I am putting a floor in for the 1st floor bedroom above the garage and in the loft above the bedroom.
1st floor:
There will be a plaster board screwed to the underside of the joists.
QUESTIONS:
What kind do I need as that will become a ceiling for the garage i.e. fire risk?
Is there some fire resistant plasterboard and does it have a ref number?
Is that the same as the moisture resistant plasterboard?
Does the moisture resistant one have a number?
Or do I need 12mm thk foil backed plasterboard? Is that Kooltherm K18?
The joists are 170 mm.
K3 kooltherm will be 60+50 mm so I will end up with a vapour barrier of 60 mm.
QUESTIONS:
Presumably the vapour barrier will have to be below the insulation so that the insulation is in contact with heat spreader plates for underfloor heating?
How do I keep the insulation layer above the plasterboard beneath to achieve the vapour barrier? Are there some kind of risers?
Is 60+50 mm sufficient insulation?
Or is the vapour barrier required only on a ground floor in which case I may want to just lay the insulation directly onto the plasterboard and top it up to the joists height of 170 mm?
Loft:
QUESTION:
What kind of plasterboard do I need for underside of the joists ceiling i.e. the bedroom below?
Would it be the K18 with 12mm thk foil back?
MANY THANKS FOR YOUR ANSWERS!
1st floor:
QUESTIONS:
QUESTIONS:
Loft:
QUESTION:
