Hi all, I am currently helping a friend to build a 5m*4m log cabin (on a new concrete base).
The supplier insists that the tanalised 3x2" floor bearers should run all around the perimeter of the cabin. The other log cabins that I have built had the cabin sitting on floor bearers (spanning the width of the cabin) that are parallel with each other, the T&G floorboards are then tacked to those.
We didn't realise that the client hadn't noticed that floor is an optional extra (it costs about another £500). We phoned the supplier who told us that they will supply uncut boards that we need to nail to floor bearers and that it will end up being a floating floor. When we asked about floor ventilation, they insisted that it wasn't necessary, adding that we could put some dpm down if we wanted. They also insisted that parallel floor bearers won't be able to support the building.
The building was supplied with 8 floor bearers. Unless advised otherwise, we are planning to stick with the parallel bearer option, buy more and space them at 12" apart, is that sufficient for 18mm T&G floor boards?. I find it hard to believe that a cabin on a new concrete base does not need ventilation- am I wrong? The cabin is L shaped, the concrete base is rectangular and slightly larger than the cabin foot print.
