Long (As in 7 feet long) Radiators?
4 Aug 2011
Lancashire
Anyone know where I can buy a really long radiator to replace the really old knackered one I've just taken off the wall? The one I've taken off is about 7 feet long (2133mm)
Cheers
You would be best going to a plumbers merchant where you will have to order one. You have probably already found that places like B&Q or Wickes only sell the more popular sizes. This firm makes them up to 2.4 m wide/long so if you are stuck you could contact them and ask where your nearest agent is:
http://www.kudox.com/Radiators/Steel Panel Radiators/steelpanelradiators.html
This thread should really be in the plumbing section.
You could also ask Screwfix as they sell Kudox rads and I think will supply the longer ones to order.
Another alternative is to use a double panel at 2000mm long.
Oversizing does not matter as the TRV will take care of that. It also allows a faster heat up and creates higher efficiency with a modern boiler.
Tony
