low level cisterns
13 Oct 2008
Glasgow
Hi
I am replacing my plastic low level cistern with a china one, is there anything i should know before intalling it or is it pretty straight forward, it has a set of brackets i presume these suport the weight of the cistern. Do i fit the brackets first then the cistern and then the fluhpipe or is there a set order in which to install it, i have been told i may have a problem when replacing the flushpipe into the back of the w.c as they almost leak every time, is this correct. Thanks
make sure the flush pipe lines up level and you should be ok.
and use a new flush pipe seal
